โJun-25-2013 03:32 PM
โJul-09-2013 08:57 PM
mitch5252 wrote:I wouldn't worry about it.
Oh, another question - can those coated wires (mainly the red one toward the center) safe touch the coil thing with the copper wire wrapped around it (I'm assuming that's a large capacitor??)
โJul-09-2013 01:23 PM
smkettner wrote:
The 4645 will operate just fine without the pendent. You can still tell what charging mode it is in (boost, normal, float) with a voltmeter. You just cannot change the mode manually and you may never need to change modes. Might leave that project for another day.
Or find out why you were sent the wrong size.
โJul-09-2013 01:14 PM
โJul-09-2013 11:29 AM
โJul-09-2013 09:50 AM
smkettner wrote:
The pin goes into the breaker empty slot adjacent to the other black wire.
Looks like you cut both leads from that pin ๐ That is OK, now you need two wire nuts. One to connect to the new converter. And the other goes back onto the other existing circuit.
That 10-30 & 40-50 lable on the breaker side is just a diagram to show how far back to strip the insulation. Yours is a 15a breaker so you follow the first if you were inserting a copper wire. But since you are inserting a pin it does not even apply.
โJul-09-2013 09:44 AM
โJul-09-2013 09:28 AM
โJul-08-2013 04:36 PM
โJul-08-2013 03:50 PM
โJul-08-2013 02:47 PM
โJun-26-2013 10:40 AM
โJun-26-2013 10:00 AM
โJun-26-2013 09:21 AM
RJsfishin wrote:
I'll talk in plain English,.......
Get a PD 9245, and you will love it. It would be plenty big for even 2 27s, and it won't overload your Honda, and you will have manual control over the charging stages, should the need ever arise.
โJun-26-2013 08:56 AM
