dirtroad2's avatar
dirtroad2
No dc voltage at distribution panel 98 Monaco diplomat
I have a 1998 Monaco Diplomat. The batteies are charged and suppling 12 volts. The Xantrex 458 inverter is working and suppling 110 volts when I am inverting. I have no 12 volt dc at the distribution panel. I can not find a converter anywhere in the motorhome. There is a ciruit board in a outside compartment on the left side of the motorhome near the front wheel. On the ciruit board there is a 12 volt red wire that comes off the board and it is marked 50amp for inside distribution panel and I have power there. but not at the distribution panel in the rear of the motorhome. I assume there is a fuse or circuit breaker somewhere but can't find it. Has anyone had a issue with this in a Monaco diplomat.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
