EMD360's avatar
EMD360
Samlex Inverter Power Draw Question
I just finished a Samlex pure sine wave PST 3000-12 inverter install. I ran 00/2 cables because that was recommended in the user manual. I added a Renogy 30 amp transfer switch with the charger wired to the shore power connections so the charger stays off when shore power is off. It is practically next to the battery compartment under the dinette seat.
I also installed the remote at the entry wall so I can see the readings without bending over like with reading the Victron meter (when not using Bluetooth) or the surge protector which I ordered without the remote by accident.
So my first test was to run the microwave for 1 minute. I was kind of shocked to see the time remaining plunge from 9 hrs to 27 min in power left after only 1 minute.
The 14.6 capable batteries were not fully charged reading 13.37 volts at start. Not sure why they were at that level as they are on shore power so the progressive dynamics 9160L should have them a bit higher.
The voltage dropped to 12.87 in a minute. The Victron reads 98% charge but only 27 min remaining power. Maybe there is something wrong with my meter settings.
Start:
End after 1 minute of microwave power used:
Does this amount of power draw seem about right for this inverter?
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
