LIKE2BUILD
Jan 08, 2018Explorer
'14 Ram 2500 Axle Seals Leaking
My '14 2500 has 120,000 miles. This summer before a big trip pulling my 5th wheel out west I found both outer axle seals leaking. I replaced them along with the parking brake shoes and have pulled over 10,000 miles since then. I just recently found the seals are leaking again :(
What's the deal with this? The pinion seal is fine, but I'm going to check the vent hose check valve to make sure I'm not building up pressure in the axle. Is there anything else that would explain these seals going out again so quick?
During the first replacement I didn't see any obvious grooves or markings on the seal surface. Is there a ready-sleeve available for the axle tube? Or, is there a double lip seal to give extra surface area to hold in the gear lube?
Final question: what is the desired fill level in the axle? I found one person talking about filling only to 1/2" below the fill plug and others talking about filling up to the plug hole. Which is it? Can over filling the axle create problems like I'm having?
KJ
KJ
