โSep-29-2016 07:10 PM
โOct-01-2016 08:20 AM
โOct-01-2016 08:14 AM
Grit dog wrote:
Running 70+psi in The front tires without additional weigh that require it is crazy IMO. Unless you just take out your false teeth so they don't rattle out!
Btw, not hard to get high miles out of bfg rugged terrains. They gotta be the hardest compound worst wet/snow/sand/anything but dry pavement tires ive ever run.
Perfect for pounding pavement cross country with heavy loads.....in good weather.
โOct-01-2016 07:19 AM
โOct-01-2016 06:06 AM
โSep-30-2016 03:44 PM
Searching_Ut wrote:
I pretty much only use my 2015 3500 for towing, and now have a little over 8000 miles on it. Gas mileage averages right around 10mpg while towing, only a couple tanks running without the trailer but hit almost 20mpg at 80 to 85 mph. DEF usage much higher than others reporting, around 12 gallons to go 8k miles. Lots of whistles and bells, even dims highbeams for me, decides when wipers need to be intermittent or full blast. GPS maps could use updates, and voice controls are worthless for the nav stuff, work fairly well with phone, text messages etc. Rear air suspension is really nice, ASIN transmission mixed bag as it tends to hunt to much. TransForce tires actually get good traction towing in snow, rain, and do good on dirt roads if they are dry and don't have a lot fo gravel. They are wearing rather quickly though. IBC is sad to the point of being dangerous. Overall though, nice truck, towing beast, acceptable on paved roads empty, a little sad on the dirt roads which is just the way it is with 1 tons.
โSep-30-2016 03:01 PM
โSep-30-2016 02:11 PM
โSep-30-2016 01:52 PM
โSep-30-2016 01:30 PM
Cummins12V98 wrote:
Your trans is unlocking between shifts and is normal for a 68RFE.
โSep-30-2016 01:27 PM
โSep-30-2016 12:28 PM
Cummins12V98 wrote:
"I run Michelin At2 tires.......Fronts are 55 psi all the time"
I know you are "OLD" but you might take some advice and run your front tires to 72psi all the time. This comes from someone that easily gets 100-120K on 3rd gen take offs. I ran 72 front of my 98 4x4 and now 65 front 98 2wd.
These BFG's have 80K.
โSep-30-2016 06:46 AM
Greene728 wrote:
First off, I love the Cummins. It still exhilarates me and makes me feel like a fat kid in the candy store every time I drive it! The power, fuel economy, quietness, and overall pure refinement of this engine is truly remarkable. I can get 21mph + or - interstate running easily (yes, that's hand calculations also) found the EVIC display to be very accurate also. DEF usage is basically irrelevant. Ive put just under 5 gallons in since new and is sitting at 10,887mi as I type this and half a tank of DEF on board.
โSep-30-2016 06:08 AM
โSep-30-2016 06:03 AM
โSep-30-2016 05:58 AM
Greene728 wrote:wowens79 wrote:
Great to hear the good review. I'm starting to research some, I'll be looking in a year or so.
I'm in Newnan also, did you get it from the local dealer? I like to shop local, but I'm also cheap.
Awesome! Nice to see another local on here.
I tried to use the local dealer in Newnan but found them hard to deal with and could not work out a deal after two different attempts.
We finally worked out a great deal at Scott Evans CDJR in Carrollton. I highly recommend giving them a shot. Our experience there was very good. The owner even took the time to come introduce himself during the deal process and was very involved in the process till the deal was done. Even called a few days later to see how things were going and asked if we needed anything. Not very common anymore these days and impressed me a lot.
Best of luck to you!
