โDec-18-2019 05:57 AM
โJan-04-2020 04:27 PM
โJan-04-2020 12:46 PM
โJan-03-2020 03:35 AM
biggjb wrote:I'm a little confused with your terminology . Voltage drop is a loss of voltage through wires or connection . When you say you had a voltage drop between the converter positive and battery positive lugs that would mean zero volts at the battery lug . Did you mean you had the same volts at both lugs ? Also , did you use the battery positive and negative lugs for testing . You definitely have an open circuit between the converter and battery . How and where do the solar charge wires connect to the battery ? In order to test those lugs as I suggested you would also have to disconnect the solar charge from the battery . You should have continuity between the converter lug and the battery lug . It's the only place I can see that the converter is connected to the battery .
Ticki2
I disconnected the battery and converter on the panel and there was no continuity. I then connected the converter back to the panel and turned the converter on and the voltage coming from the converter was 13.65. however, just for giggles I checked for a voltage drop across both positive lugs of the converter and battery. There was a voltage drop of 13.65 volts. This made no sense so I tested it several times and it came out the same each time.
As for charging my battery I also have a 130 watt solar panel which kept the battery charged.
โJan-02-2020 02:19 PM
โJan-01-2020 07:28 AM
โDec-31-2019 02:20 PM
โDec-31-2019 11:45 AM
AnEv942 wrote:
The 'blue' wire mentioned was the lead from the old Mag. converter to the circuit board. The new P/D converter lead isnt blue, Mine was black, (current units may be red?). Would be outlined in instructions.
Assume you changed the board
Ya if no 12v when plugged in and battery off, something is disconnected.
Trying to see how you could have 12v to fuse panel yet not charge.
possibly battery connected to the converter terminal on board?
โDec-31-2019 11:38 AM
Photomike wrote:AnEv942 wrote:
my 2 cents- with battery on and camper AC connected, converter on- multimeter should show converter voltage at both battery & converter positive lugs.
With converter turned off (breaker) you should see battery voltage at both terminals.
If converter voltage shows at battery board terminal, Id pull the battery cable lead from converter at battery and check voltage there-should see converter voltage from converter on cable. Pulling battery lead at board terminal should see battery voltage on cable.
For some reason (short of converter malfunction) with what so far has been related- makes me think some how cable from battery is one way, only sending battery power to converter but power cant travel back. I cant see how that's possible unless whatever was added as disconnect has that function?
Everything that others are saying is correct and it should be simple to check. What I am wondering is if there is not another cut off on the line to the battery maybe to isolate it, maybe even a switch on the battery terminal. Can you follow the wires from the charger to the battery all the way or do they disappear behind a wall someplace? If you have zero 12v working when inverter is off then something is shut off.
I would run two lines from the charger to the battery across the floor and then see what happens. This would tell you if it is the lines that are installed.
Many old units did not have a battery, they only ran the 12v when they were plugged in or from the truck.
โDec-21-2019 04:57 PM
โDec-21-2019 04:08 PM
โDec-19-2019 08:12 AM
โDec-18-2019 07:30 PM
biggjb wrote:Could be off your picture but I am not seeing ground/white wire from converter connected to the ground lug on fuse panel , only battery ground .AnEv942 wrote:
possibly battery lead connected to the converter terminal on board?
Your installation is very similar to mine. The lead wire on my board is black as well as you can see in my photo
and yes I did change the board. My only concern is the positive wire from the battery. I will have another look at it tomorrow.
โDec-18-2019 06:59 PM
โDec-18-2019 03:14 PM
