Ron3rd's avatar
Ron3rd
Explorer III
Jun 22, 2018
Better way to change rear fuel filter on 2016 Cummins?
Does anyone know a better way to change the rear fuel filter (water separator) on a new generation Cummins without getting showered with diesel fuel?
I've done it twice now and always get a lot of fuel pouring out when I loosen the filter. I open the drain prior as required, but it seems a lot of fuel remains somewhere.
BTW, don't have a lift, can only do it on my back on the ground.
  • I piece of clean plastic hose that fits rear filter bib, slides inside the hose front hose. Have a jar or bucket to catch the diesel. Put it with a light used engine oil for magic fire starter. Chris
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    azrving wrote:
    Open the drain for awhile. Remove the water sensor connector. Remove the whole sensor assembly. Put a garbage bag around the filter and remove it.
    You can buy a longer hose for the front drain and tuck it out of the way.
    Front one's easy. The garbage bag might help
  • Open the drain for awhile. Remove the water sensor connector. Remove the whole sensor assembly. Put a garbage bag around the filter and remove it.
    You can buy a longer hose for the front drain and tuck it up out of the way.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    It has a spring loaded check valve. Unscrew it a couple turns before opening the drain.
    By "unscrew it", you mean the filter or the plastic sensor at the bottom?
