cjelliott81
Apr 05, 2016Explorer
Keystone Customer Service Fail
BUYER BEWARE! - KEYSTONE WILL NOT STAND BEHIND THEIR PRODUCTS.
An improperly installed (upside down) cargo door has caused thousands of dollars in water damage to my camper and despite a diagnosis from two different authorized Keystone dealerships that that the door is improperly installed, Keystone refuses to take responsibility.
The door is installed such that the weep holes that would typically allow rain water to simply drain out of the door are located on top of the door rather than the bottom (see photos). This allows the door to fill with water during rain showers until it completely fills the door and weeps between the door panels and the black frame that binds each side of the door together ( not to be confused with the door frame that the door seals against when closed).
Per Keystone customer service, "... they stated they do not believe a manufacturing defect. It would be deemed no assistance from Keystone RV. They deemed that the weep holes would not allow water into compartment." This is despite the fact that it has been diagnosed as an improperly installed door by two of their service centers, video of the water running down the door obviously from the door seams and not from the frame, and photos of corrosion on the interior of the door from the water seepage.
Photos: https://goo.gl/photos/5Aa9mdqgHAdAF52GA
Video of leak: https://youtu.be/PpWkQt6AMlU
