Blazing_Zippers
Jul 24, 2017Explorer II
lost the clearance lights
We plugged in and checked the lights (we check everyday before heading out), and all was good.
Well, later on, the tail light/clearance lights were out. Turn and brake lights were fine. After checking, I found the fuse was blown--(you know--one of those expensive one of a kind fuse).
The replacement fuse also blew as soon as I plugged in the light plug from the fifth wheel to the TV.
Any ideas? I hate electrical problems because you can't see what the issue might be.
I would like to fix the issue myself, then I might be able to repair it in the field if it happens again.
