bmwbob's avatar
bmwbob
Black water gate valve replacement
Our '99 DSDP has a Valterra 3" Bladex gate valve in the black water line which appears to be leaking (down the tube, not out of the valve body).
It LOOKS like I should be able to simply remove the four stainless nuts and bolts that mount the valve in the drain, and pull the defective valve straight out, simply reversing the procedure to install the new one.
Is that about it, or is there more to this job than meets the eye?
Bob
