atsrmf
Feb 17, 2018Explorer
Transfer switch
I finally got my Onan generator running and it puts out good voltage, 122. The problem is, it doesn't seem to connect to the RV panel. When I plug in the RV everything works fine, but the generator does nothing. The Onan breaker is closed and the 5 amp fuse is good.
My motorhome is a 1987 Gulfstream. I assume there is a transfer switch somewhere, I can't find it. I also assume that it should throwover to the generator when it comes on. I did not have the RV plugged in when I made the test.
This is my first experience with RV generators. I do electrical work in both cars and residential, but this has me stumped! Any suggestions? The manual gives no information, not much came with the motorhome when I bought it.
