JackMS
Jan 06, 2014Explorer
Heat pump working at 28 degrees ambient
I did an experiment with my heat pump tonight. Wanted to see at what temp it would switch to the furnace. It is down to 28 right now and the heat pump is still running blowing 104 degrees out the vent about 3 feet away. I would have thought it would have iced up by now but doesn't show any signs of it. Temp inside the mh is about 42.
Should I be impressed it's doing so well or worried it hasn't switched to the furnace? I am going to switch it manually before I go to bed if it doesn't do it on its own.
