jlscjs's avatar
jlscjs
prodigy brake controller ( I need help)
I have a prodigy brake controller and lately I have not been feeling the trailer brakes being used. I tried to set the control by moving the lever all the way to the left and turning the left dial to 6volts. When I do this it reads 12volts to start with then counts down to 0volts, I cannot set it at 6volts, is this a result of a bad controller? I've tried numerous times to follow the book to set it to 6 volts but no luck, also when I crawl underneath to test the current on the wiring I'm showing nothing,
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 20, 2026
