Halmfamily wrote:
rhagfo wrote:
Rosebud wrote:
I have a 2005 6.0, and love it. Just returned from 15,000 roundtrip to Alaska. Pulling a SunnyBrook 31 BWFS and no problems except with the brakes on the 5th wheel. Truck preformed just fine. I did replace the EGR cooler and oil cooler at 95,000 miles. I think this truck is one of the best I have ever owned. Love driving it.
It is true that the market is depressed on the 6.0 powered trucks but they can be a good deal. Regular maintance is a must, use Motorcraft filters and Synthetic oil, (I use Rotella T-6). Change coolant regularly and enjoy your ride
Bill
By 2005 Ford/Navistar had made updates to the engine and the Failure rate was much lower. The Billion dollars, were for the many crate engines used to replace the early 6.0's, 2003 and early 2004. We had some friends that had an engine replacement on theirs.
I wish someone would have told that to my 06 6.0...
Yeah, really! The 4- 2006 and 1- 2005 Powerstrokes we own(ed) have all went through all the known problems. EGR, blue spring, HPOP and fitting, head gaskets, injectors, crank and cam sensors, turbo boots , Y-pipes and FICMs. That's just the motor.......
I just had to put a long block in the 2006 I drive at a measly 176,000 mi(broken valve caused by a dropped lifter). I'm now finding out that this is another problem that is happening. Shops are having the heads machined and there is not enough tolerance to allow for this. Ford recommends replacing the heads if they are out of spec and now I know why. The push rods are so long that it bottoms the valve spring out which causes the stress on the lifters. I was told this by the shop that I bought my long block from and all they do is specialize in re-manning 6.0's. I also talked with another shop that said they had two in their shop at that time for the same problem.
