Pangaea_Ron
Sep 27, 2021Explorer
Radial Tire Valve Core Failures
My front radial tires are Toyo 245/75R 22.5.
When checking air pressure (105 pounds), I occasionally have the cores fail which allows air to escape dramatically, and I need to scramble to get the cap back on the valve stem on or replace the cores. This time I took it to Les Schwab Tires for them to check air pressures and to replace the valve cores. Both front tire valve cores had failed.
This seems to happen about every 6 months. Does anyone else have this issue. They said that it is common with high pressure tires?
