pirlbeck's avatar
pirlbeck
Solar experts....Matching solar panels help needed.
About a year ago I picked up 3 unused Kyocera KC50 50Watt panels for almost nothing and would like to put them on my 2009 Lance 845. While open roof space is somewhat limited on this roof, I think I would be able to find room for at least another 50 watt panel and I need help picking a panel that would work well with the 3 I have. I have looked at buying one or 2 larger panels instead of using the 3 I already have and most on these are too large to fit with the available roof space.
Here are the specs from the tag on my existing panels.
Pmax @25C 50W @45C 35.8W
Vpmax @25C 16.7V @45C 14.7V
Ipmax @25C 3A @45C 2.44A
Voc @25C 21.5V -----
Isc @25C 3.1A -----
Max Sys V 600
Series fuse 6A
Dimensions 25-1/8"X 25-5/8" Dimensions are not critical as I will be mounting the 3 panels I already have in one row and the 4th panel will be mounted alone.
Here are couple of panels I am looking at.
https://www.amazon.com/dp/B01CRA5WNU/?coliid=I3NDL237AHNBVG&colid=11UZ2A09YMR7C&psc=0&ref_=lv_ov_lig_dp_it
Maximum Power Pmax 50 W* (0%, +3%)
Cell type Poly silicon
Voltage at Maximum Power Point Vmpp 17.5 V
Current at Maximum Power Point Impp 2.86 A
Open Circuit Voltage Voc 22.0 V
Short Circuit Current Isc
3.17 A
Module Efficiency (%) 12.5%
Temperature Coefficient of Voc -0.37% /oC
Temperature Coefficient of Isc +0.035% /oC
Temperature Coefficient of Pmax -0.50% /oC
https://www.amazon.com/dp/B0159PHIXW/?coliid=I1VEFUGQTEKM21&colid=11UZ2A09YMR7C&psc=0&ref_=lv_ov_lig_dp_it
Maximum power (Pmax): 50W
Voltage at Pmax (Vmp):17.2V
Current at Pmax (Imp): 2.91A
Open-circuit voltage (Voc)?21.6V
Short-circuit current (Isc)? 3.23A
This last one looks pretty close to me, or am I missing something?
With 3 panels, I had planned to wire all 3 in series but if I add a 4th panel I may do 2 panels in series and then parallel the 2 series sets together.....provided my factory Lance 12ga wiring is heavy enough. I really would like to avoid pulling or routing new, larger wiring from the roof down to the solar charge controller. I installed a Trimetric 2030 and wired in a second battery that sits in the bed of the truck and pulling new wires/cables is not a lot of fun in a smaller truck camper like this 845. I can use larger wire/cable from the controller to the batteries, so that is not an issue. If the 12ga wiring is not heavy enough I would probably wire all 4 in series.
For a charge controller I am planning on a Victron SmartSolar MPPT bluetooth controller.
Also, what size fuse(s) would I need for either way of wiring?
Sorry about the length of this.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
