BigDogF250's avatar
BigDogF250
Chasing Electrical Gremlins - Questions
So, keeping the story short, trailer was working for 8 hours after travel, then in the middle of washing my hands, the whole trailer went dark, losing all power.
At all times the battery checks at 12v, but I will load test tonight.
The ?'s
- Why does the converter control the ground? From the frame to the converter then to the ground bar where all other connections go. I add a direct ground and that helped (for a while).
- Do I need to keep it that way? Seems like a recipe for issues.
- When not working I was seeing as high as 3v and as low as 1 volt at the inside of the trailer. Battery checked at terminals, 12.8v.
- When running on generator it's fine, meaning the converter seems to be working. So I put about 16 hours on the gen this weekend.
Welcome any comments. I am very familiar with 12v wiring, but this one has me stumped. My next plan is to replace the wiring and fuses from the battery to the panel with a single cable, probably 4 gauge unless something bigger presents itself. I really have no intention of adding an inverter unless the converter is faulty, my camping style works well with 12v. Then bigger cable to the batteries and maybe 2 outlets live on the inverter.
That and 2 flat tires on the MX bike made the weekend less fun but the tequila and beer were cold so it all worked out.
