Dry camping for night at Victoria Coho ferry terminal
NEOK
I understand you you can spend the night inside the gates at the Victoria Bkack Ball COHO ferry terminal. Has anyone done one this and how does it work?
neok
2009 GMC 25000HD Short Bed 6.0 Gas Engine Crew Cab SLT 4x4
2008 Bigfoot 15C9.5FS
Torklift Talons, Fastguns, Stableload Quick Disconnects, Superhitch & SuperTruss
5 REPLIES 5
Orion
Yes we have stayed there a few times. No problems, and as for "is it safe", even with all the rubby-dubbs here, it's still very safe.
Sometimes I sit and think deep thoughts. other times, I just sit!
garyhaupt
It is behind a wire mesh fence and it's Victoria..of course it's safe. And it's right in the quiet area of the harbour. The most noise you will here will be from float planes and choppers, and they are out of service after dark.
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
sue_t
I did that about 20 years ago. It was noisy. Busy. Imagine it isn't much better now with the increased numbers of homeless people in the downtown area of Victoria.
sue t.
Pictures from our many RV Adventures to Yukon & Alaska from Vancouver Island. Now we live in Yukon!
NEOK
I need to clarify my original post. I talked to the Black Ball Ferry Line and they say you can spend the night inside the terminal gated at the Victoria terminal if you are inside the gates after the last Ferry sales at 7:30pm and before 8:30pm.
My question is has anyone spent the night inside the gates and what is it like? Is it noisy and is it safe?
neok
n7bsn
I'd call the BlackBall Lines and ask them.
I haven't ridden the ferry regularly in years (I used to ride it weekly), back then the answer on Port Angles was nothing overnight. They did allow parking (no slides) at Victoria, but not PA
There is an RV park very nearby (Peabody Creek)
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
