Oct-30-2010 06:09 PM
May-19-2011 01:41 PM
Tom&Dale wrote:
Alternate location for ignition button. Keeping the old one as a backup as well as a reminder how much better the new setup is.
Thank you for the idea 12thGenUSA
Photo in 5th wheel album: E-Ignition...
May-19-2011 01:13 PM
ralphnjoann wrote:
I thought the easy part would be routing the wire from the oven igniter to the control. Wrong! I've tried a coat hanger, a flat piece of plumbers strapping, and the wire itself in both the right and left openings behind the top burners going from top to bottom and bottom to top and I can't get it to go through. What am I missing? Thanks. Note: The stove is an Attwood.
May-19-2011 10:47 AM
May-19-2011 09:23 AM
May-18-2011 09:41 PM
May-18-2011 05:57 PM
Dutch_12078 wrote:Duramax1 wrote:
This information is for those of you with a Magic Chef stove that does not have any ignitors.
Last year I investigated doing this project and, like others above have noted, discovered that the four wire ignition kit from Home Depot is too high to fit in the stove.
This year I discovered that WalMart has a three wire ignitor kit which sells for $15.97 in Canada which will fit into the stove. I used a 25mm hole saw kit to cut the circular hole in the front stove panel.
Can you post a photo showing how you mounted the ignitors at the burners?
May-18-2011 08:48 AM
May-18-2011 08:04 AM
tvman44 wrote:You might try the camping section in Walmart or any sporting goods store. They sell small metal mirrors for campers and backpackers.
trucker Lou,
Where did you find a stainless mirror to mount on the door?
I had thought of putting a hand-held mirror on the door to verify ignition and remove it before closing the door but I like your idea better.
May-17-2011 04:58 PM
May-17-2011 04:46 PM
May-17-2011 04:23 PM
May-12-2011 03:27 PM
Duramax1 wrote:
How are you going to make the hole in the front of the stove to accommodate the ignitor mechanism?
May-12-2011 03:12 PM
trucker LOU wrote:
I cut a trim plate from black plastic Folgers coffee can lid. white plastic ? dairy products plastic lid ? I also attached (pop rivet)a small stainless steel mirror to inside of oven door. allows me to check for flame while standing.
May-12-2011 02:45 PM
May-12-2011 01:30 PM
DD716TED wrote:
Since my Suburban Stove had no previous ignitors, I have to install 3 of them... I have made sheet metal brackets and mounted the insulator/spark devices to them... QUESTION... will mounting these brackets directly under each burner to the metal bottom of the stove panel with short 1/2" sheet metal screws hurt anything?... I am sure there is a considerable gap / insulation between the bottom of the stove and the oven liner but I thought I would ask first..
