On demand water heater installation
jlegere
does anyone know of a device that will turn off one circuit when another is turned on? I would like to disable my a/c when the on demand water heater is turned on. this will keep me from popping breakers when the water heater kicks on.
8 REPLIES 8
AmericaOverland
It appears you need higher amperage than is designed for RVs in order for on-demand water heaters to work well in shower environments. I really wanted to look into this, considering that I'm a woman with long hair. I just have to shower twice, once for my hair, and second for my body. Fortunately, given my farm lifestyle, I only do the former about twice a week and the latter every day, just a five-minute rinse down to warm up or cool down, depending on the time of the year.
Chris_Bryant
I do not believe an electric on demand water heater is practical in an RV, unless it is a 50 amp rig, and you don't mind spending more than half of that capacity on hot water. Most I have seen are 30 amp/240 volt units- 20 amps at 120 volts just is not going to heat water on demand very well.
Looking- a 3400 watt 120 volt model only gives a 35 degree rise at .7 gpm- not enough for a shower to me, just enough for hand washing.
-- Chris Bryant
rv2go
jlegere wrote:
not exactly sure but the device that will take priority will be an on demand electric water heater. the secondary will be the a/c unit so a 20 will take care of that side.
It's really hard to help not knowing what you need amp wise.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
jlegere
rv2go
jlegere wrote:
that is exactly what is needed, but in higher amperages.
What amperage are you trying to shift? They make the same device in 30 Amp.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
jlegere
rv2go
I think what you need is a 20 Amp Automatic Load Shed Device. You just set the one that you want to be priority. Some RV's have an Engery Manage System that does the same.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
camperpaul
A 20 Amp SPDT (3 Way) switch will do the job for you.
Not high tech and cheap (under $10.00 for parts).
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
