2008 Cameo 33ckq Kitchen slide motor
rcg270
FYI
The slide motor to the kitchen slide began to slip upon returning home over the holiday weekend. After inspection, I found the "hex gear" to the slide motor slipping with the "slide gear motor," in other words the two gears were not meshing properly.
When I pulled the motor the mounting bolts for the motor were not tight at all! Also the "hex gear" was worn and had to be replaced. I disassembled the gear box to the motor, re-seated the hex gear shaft into the housing, and repacked with grease.
After re-install, slide moves very smooth with very little effort.
5 REPLIES 5
TXiceman
There is a Carriage Lifestyle forum that has details on how to repair the loose slide motor issue.
http://www.carriage-lifestyle-owners.com/portal.php
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Durb
Garry&Gayle wrote:
Carriage Parts
They bought out RBW who made the original slideout parts.
Thank you. No need yet but I have made a note for down the road.
Garry_Gayle
Carriage Parts
Durb
Welcome to this forum. I'm sure you will find much of the information here helpful.
I'm glad to hear you can still get parts for a Carriage product. Who manufactured the slide motor mechanism and where did you source your parts?
Garry_Gayle
Put locktite on those motor mounting bolts unless you like doing it more than once.
