2014 puma 356qlb
smadden210
I apologize if this has been covered before. I am new new new to the 5th wheel community.l and over 20 years since having a camper in general. My slide out does not work on my csmper and i am looki g for ideas to search out. Ive replaced the switch to operate the slide out just for kicks, also put a good battery in because it says "battery hook up required for slide out operation" i do not get any clicking, or any sound, any slight movement...etc, etc...i get nothing. Can someone PLEASE tell me what else to try or do? Camper is still mounted to truck if that matters.
3 REPLIES 3
fj12ryder
Is this an electric slide, or a hydraulic powered one?
Howard and Peggy
"Don't Panic"
MFL
Nomad II
Nomad II
Did you check for power at the switch, when switching out? Do you have a battery disconnect switch? Also check solenoid breaker, not far from battery, usually on inside basement wall. If you have a meter to check voltage, follow the power where you can, to confirm.
Did you hook battery up correctly, to not blow reverse polarity fuse?
Good luck, welcome to the forum!
Jerry
dedmiston
Moderator
Moderator
Moved from Good Sam Club to Fifth-Wheels.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
