5th wheel receiver hitch latch not completly closing
luggage
I moved my 5t wheel camper at my home today because I noticed the Wheel Masters level on the King pin tongue was a bubble and a half off to the left. We've had a lot of rain and the gravel drive is not completely level. Well I hooked it up and the coupler on the hitch closed. But apparently not completely because the handle that opens and closed the receiver latch is completely returning to the closed position and not matching up with the hole on the hitch to place the locking pin through it. I am very new to fivers coming from a TAG and still getting use to the hitching and unhitching. What should I do to get the locking coupler to completely close so the handle will seat properly. I hope I have explained the issue clearly. Apologies if I sound clumsy. Thanks
16 REPLIES 16
Sturgeon-Phish
What type of hitch? Most of the time if the hitch does not latch it is due to the jaws not being complety engaged or in a bind.
If you are connecting up, I'd reverse what you've done, pull away and start over. You may be high hitched or off side to side.
When you connect, are you following the manufacturer's instructions? Most have you starting off with the jaws open and the kingpin about an inch below the platform?
Jim
2003 GMC 3500 crew dually. Transfer Flow 50g aux tank; ISSPRO gauges, PPE boost valve, air box mods, stock exhaust w/o muffler, Line-X, Pace Edwards bed locker power tonneau. B&W Companion. Pulls a '05 Wildcat 31QBH 5th wheel
Nutinelse2do
Could be as simple as it is gummed up, time for some spray graphite, and a little elbow grease. It maybe mechanical issue but always start with the basics first.
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
