Battery Maintenance
4x4ord
I'm refreshing my somewhat limited knowledge of battery maintenance and found this article to be quite helpful.
My Renogy solar charger is supposed to automatically do an equalizing charge every month. I think I'd rather do that on an annual basis with my Xantrex charger.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
3 REPLIES 3
allen8106
All that article is is some clowns opinion. Equalizing should be done monthly.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
pianotuna
Nomad III
Nomad III
Nice find!
It misses talking about balanced wiring for multiple batteries.
Here is that information:
http://www.smartgauge.co.uk/batt_con.html
Regards, Don
bpounds
I also found a monthly stir to be excessive when I had flooded batts. But check your Renogy documentation. A good CC should allow you to customize all parameters involving charging voltage and routines. If you had AGM batts for example, you would need the equalizing function disabled. So most can do that.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
