Care of Tires for Long Term Storage
ReneeG
In a recent article I read on how to care for tires during long term storage, it said to block the tires. Does this mean to lift them off the ground and support the axles? If so, does anyone do this? The alternative was to get the tires up off the ground to prevent absorption of ground moisture which also contributes to aging. This article suggested placing nylon blocks, similar to a nylon kitchen cutting board under each, or sheet metal over wood. What do most of you do for long term storage, i.e. over the winter, aside from covering them?
2011 Bighorn 3055RL, 2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3, 1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica, Mabel, and Melton
17 REPLIES 17
ReneeG
Thanks Chevman and the bear II, ours sit on gravel and are covered. I heard somewhere that asphalt can leach the oils out of tires, but since you have gone beyond 5 years, that may be an "old wife's tale"
the_bear_II
My tires end up being beyond 5 years old before they show signs of wear from storage. Mine sit on asphalt and I keep them covered with vinyl tire covers.
I have had to replace three sets of tires due to old age vs. wear over the 20 years we have had our current RV.
larry_barnhart
We use plywood for home and for the 6 months in Arizona.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
