Caulking underside of cap
larandjane
What is best type of caulking to use on underside of fifth wheel cap
Larry and Beautiful Wife
2005 HR Savoy 29RKS 2007 Chevy 2500
1 REPLY 1
SteveB
I just used LEXEL (clear) to reseal around the entire front of my Jayco. The LEXEL was only the secondary sealant though. Across the top aaluminum to roof joint I applied Eternabond tape and along both corner trim I applied Dicor Seal-Tite tape. The LEXEL was used between the metal trim and the tape especially at each screw hole.
Unfortunately the useless butyl tape had failed long ago even though it looked OK from the outside and there were some rotted wood repairs required.
Te LEXEL is easy to use and a wet soapy water finger cleanly tools the slealant into place.
2015 RAM 3500 CTD Auto 4X4 CC Dually, Reese 20K
SOLD 8/2015 '01 Dodge Ram 3500 CTD HO 6sp, Reese 15K Pro w/ Kwik Slide, Prodigy
'04 Jayco Jayflight 28.5RKS
