Check valve
Wisconsin_Bums
Have a 2014 cedar creek. There is a check valve in it . It switches between fresh water and black water flusher.The darn thing leaks had new one put in, that leaks. Both are plastic. Repairman wants to put in a brass one, he said they are best. Anyone else have this problem?
4 REPLIES 4
fj12ryder
TXiceman wrote:
I leave the leaking check valve there and add a manual ball valve that I shut off and open as needed.
Ken
I think we're talking about different things. The plastic anti-vacuum will leak all over the inside of the wall if you try to use it and it's broken. The ball valve won't help that.
Howard and Peggy
"Don't Panic"
TXiceman
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
fj12ryder
Yeah, these anti-vacuum plastic switches are a known problem. Your plumber is correct: replace with a brass one and you won't have any more leaks.
Howard and Peggy
"Don't Panic"
newman_fulltime
they are a common thing for leaking.Put the brass one in
