โMay-30-2017 04:41 PM
โJun-14-2017 01:57 PM
โJun-14-2017 11:10 AM
โJun-12-2017 08:28 AM
DReisinger wrote:
As mentioned previously, you may have a grey tank for the galley. I did and didn't realize it. After bursting the tank with to much pressure trying to flush drain line,a new tank was ordered and a $ 600.00 lesson was learned. By the way, old tanks make good lube plates for the hitch.
โJun-12-2017 07:52 AM
โJun-11-2017 06:09 PM
โJun-03-2017 08:07 AM
โJun-03-2017 05:45 AM
laknox wrote:Cummins12V98 wrote:Coach-man wrote:
The problem is you leave the valves open! The system is not designed to do that, you get build up and it clogs the pipe. To try and fix it you need to open the hot water faucets and hope it is enough to dissolve the build up! Both tanks, black and grey are called "holding" tanks. They are called that for a reason, they hold the contents, and then are drained. This action "sweeps" out any build up and keeps them clean! If you are able to get the tank clean, please do yourself a favor, and keep the valves closed, until the tank is full, then drain! Simple concept, why do so many people think they know more than the engineers who designed and built these systems?
When hooked to sewer I have left my grey tank open, been doing so for many years and full timing for nearly 6. I do once a week turn on tank spray, close valve and fill tank while doing black tank then open.
Never been a fan of being in the shower with the pan filling from the tank being full.
Personally, that's why I check the monitor =before= I get in the shower. :B Also, DW knows where the grey water handle is... :B
Lyle
โJun-02-2017 06:56 PM
โJun-01-2017 10:29 AM
โJun-01-2017 05:57 AM
โJun-01-2017 05:45 AM
โJun-01-2017 05:31 AM
โMay-31-2017 05:25 AM
โMay-31-2017 05:23 AM
