Does Your Bed Cover, Cover Your 5'ver Hitch
fivewheelhut
Hope everyone is well. Question I have is do you have a bed cover, ( roll up like a Retrax Pro ) that " clears " your fifth wheel hitch as it's closed.
If so what type cover and hitch and truck do you have.
Thanks so much
30 REPLIES 30
austinjenna
I have the retrax on a f350 and it covers the trailersave bd3 hitch
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
blofgren
I have the Ram (Curt) 20K hitch and Retrax rolling tonneau cover. I have to bungee down the handle on the hitch so that it will clear the cover but otherwise it works great.
BTW I had a Roll N Lock on my last truck and find the Retrax much better.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
ol_Bombero-JC
Fold-A-Cover, Pullrite SG. Covers it just fine.
Maybe the Q should be...
Does anyone have a cover (brand) that does *NOT* cover their hitch?..:@
....by intent - or accident (bad choice) and maybe wish they didn't have that brand!
JAC1982
We have an Extang Solid Fold 2.0. It is easy to install since it's just clipped on, and can also be totally removed with no damage/holes to the truck. It clears the hitch just fine.
2020 Keystone Montana High Country 294RL
2017 Ford F350 DRW King Ranch
2021 Ford F350 SRW Lariat Tremor
NEnative
I have a paragon tonneau cover on my 2016 f350. it clears the hitch in my bed.
BB_TX
Pace Edwards Full Metal Jackrabbit covers my Reese Elite.
JKJavelin
I have a Ram with the Backflip Fibermax. My Demco Autoslide fits under the cover fine when closed up, even with the picture frame adapter for the Ram puck system. The Fibermax is a 4 section cover and when towing I fold 3 sections forward and it locks the 3 sections in place (flat). I'm extremely happy with this setup. Everything works as it should-- Quick & easy.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde AllTrek 4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017-2022 555 Nights
2023- 106 Nights
bpounds
Mine is F250, with Retrax rolling cover.
But I think they are all going to clear a cover. Unless you had your hitch head adjusted up above the level of the bed sides, and I don't think any normal setup is going to do that.
However, the release handle may hit the cover. Many of us have shortened or otherwise modified the release handle so that it doesn't stick up. This is something I would recommend on a Reese hitch whether you run a cover or not, because in my opinion that release handle sticks upward far too much.
Also, when I am not towing and the cover is closed, I use a bungee cord to keep the hitch head tilted toward the driver side. That keeps it from banging around while I'm driving, and also keeps it from tilting so that the release handle would hit the underside of the cover.
It all works together great actually. When hitched up, the rolling cover goes right up next to the pin box, locks there, and keeps weather off the front end of my bed and also reduces air turbulence toward the rear of the bed.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
htss
I have a Truxedo rollup with a B&W Companion on a 2012 Silverado 2500. My only complaint is that the rails add about an inch of height to the bed sides and thus I lose about an inch of clearance from the bed sides to the fifth wheel.
2012 Chevy 2500HD DA - 2009 Open Range (33.5' fifth wheel) - B&W Companion - 40 gallon aux tank - Myself, wife and two kids
Keithk3628
I have the Retrax pro on my 2016 F350 and it covers my B&W Companion hitch with room to spare.
Thermoguy
I have a Pace Edwards Full Metal Jack Rabbit and it covers my B&W Companion hitch no problem.
2015 Chevrolet Silverado 2500.
cummins2014
Tuxedo Low Pro, and the Andersen rail mount hitch . Had a Reese slider before that with the same bed cover . Yes it covers it nicely ๐Ÿ™‚ Wouldn't be without a bed cover when not towing .
I had a roll-N-lock and it covered my hitch no problem... I now have a Pace Edwards Full Metal Jack Rabbit and it too covers the hitch.I like them BOTH ..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Michelle_S
I have a Roll-n-Lock retractable and it covers my Comfort Ride Hitch which is at it's highest setting without a problem.
Now with some Hitches you might have to turn the release arm 180 to clear, had to do that with my previous Reese 20K.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
azdryheat
FYI, you only need to post the question once.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
