โAug-04-2019 10:06 PM
โAug-05-2019 05:48 PM
โAug-05-2019 02:38 PM
fj12ryder wrote:3 ton jack will be fine. Most of the weight is on the wheels. You are only lifting 1/2 of the tongue weight. Probably just broke the shear bolt in the tube that runs between the jacks.
A 3-ton jack probably won't be strong enough to do the lifting. You might need a 10 or 12 ton jack to do the job easier. What and how did it break?
โAug-05-2019 01:36 PM
2001400ex wrote:The shear pin breaking would not cause the leg to drop, I would be looking at problems within the leg itself. And I definitely would not be using the stabilizers until the issue is sorted.fj12ryder wrote:
Could you describe "broke the gears"? Which gears and how do you know they broke?
I just raised it up trying to get it off the hitch. Then the one side there was a loud clank and it dropped an inch or two. I'm not sure if it's the sheer bolt, or the gears, or what it is. I haven't had a chance to look at it.
โAug-05-2019 01:16 PM
โAug-05-2019 11:57 AM
โAug-05-2019 11:56 AM
โAug-05-2019 11:49 AM
โAug-05-2019 11:47 AM
โAug-05-2019 11:16 AM
Njmurvin wrote:
Are you certain it's the gear and not the shear bolt? From your description, the system was straining to lift the trailer. It's the shear bolt's job to break first to protect the gearbox, leg gears, etc. from excess stress.
โAug-05-2019 11:07 AM
โAug-05-2019 07:31 AM
Thanks for the responses!!!
For the Jack, the right side works, so I just need the weight on the broken side.
I was just lifting it off my pickup in my driveway. I have the Anderson ultimate hitch which requires it to be lifted a long ways and it was struggling to get off the hutch for some reason then the one side broke the gears. I was able to get it off as it grabbed again but that's it.
โAug-05-2019 07:26 AM
โAug-05-2019 06:57 AM
โAug-05-2019 06:33 AM
