GFI Tripping
BobbyDale
Just survived our first frigid (16degrees) night here in the panhandle of Florida. Only our second night in our Fuzion. ( really newbies). As I was making coffee the GFI kept tripping. I finally set the frig on LP and was able to finish coffee. Is this the norm? The GFI is a 15 amp breaker! Thanks for all replies!
17 REPLIES 17
RustyJC
You most likely have a bad heating element in the fridge. Absorption-type RV refrigerators use heat to cool (I know, it seems counterintuitive) with the heat coming from either an electric heating element or a propane burner. If the heating element is leaking current to its grounded sheath (not uncommon), it will trip a GFCI-protected circuit. A replacement heating element will most likely take care of your problem.
Edit: Sorry, I misread your post. If your fridge ran OK on electric without the coffee pot, it's probably OK. If the fridge will run independently and the coffee pot will run independently without tripping the GFCI but the breaker trips when you run them together, I suspect you're tripping the breaker due to overload, not the GFCI due to a ground fault.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
VintageRacer
Is the breaker tripping from an overload, or is the GFCI tripping because of a ground fault. It sounds like it's just a simple overload if you were able to set the fridge onf LP and removing that load solved the problem. A coffee maker is quite a high load which is why home kitchen outlets are now required to have dedicated breakers to each outlet. I would just set your fridge on propane, leave it there, and stop overloading your circuits. If you have other outlets on other breakers that you can use, spread the loads among them.
Brian
2005 F250 Supercab, Powerstroke, 5 speed automatic, 3.73 gears.
20 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
1980 MCI MC-5C highway coach conversion
2004 Travelhawk 8' Truck Camper
WyoTraveler
Assuming you are running 50 amp, it shouldn't happen. Are you also running extra electric heaters since it is 16 degrees. I was in a RV park last year and had circuit breaker problems. It was the park wiring.
