Fairly common if you look at used RV's.
It's likely not over tightening but differential contraction when it gets cold. Sidewall of the trailer contracts more or less than the plastic cover, the screws can't move...so something gives...in this case the plastic cover.
Drilling them out a little larger and putting a rubber washer in should help by allowing a little movement around the screws.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
