Power landing jacks
Casinojunkie
I have power landing jacks on my 5th wheel.
Just yesterday I noticed that the motor moves up and down and side to side when operating. Should this be happening? What is the fix if not. Thank you.
1997 Dodge Ram 3500 Diesel, automatic, pyro-boost-tranny temp on pillar mount, 354 rear gears, prodigy brake control,
2002 26' Lakota 5th wheel, 3-slide, by McKenzie
6 REPLIES 6
Casinojunkie
Thanks to all, it set my mind at ease.
IdaD
Yeah mine does that too.
2015 Cummins Ram 4wd CC/SB
Charlie_D_
Mine wiggles.Check to make sure all the fasteners on the system are tight and then ignore the noise and movement
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
B_O__Plenty
Normal.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
fj12ryder
Yeah, that's normal. The motors are pretty free to move around due to the design, if you have a single motor drive with the cross shaft.
Howard and Peggy
"Don't Panic"
MFL
Nomad II
Nomad II
I think it is normal for the motor to have some movement. Mine has moved around since new, but works well, and is fairly quiet.
Jerry
