โMar-19-2017 07:47 AM
โMar-19-2017 06:40 PM
rjstractor wrote:
I noticed that the OP stated he had an E450, not an F450. Big difference between the two trucks. The commercial version of the F450 has a RGAWR of about 3000 pounds more than the E450 as well as a longer wheelbase for a given cab-to-axle ratio. So, towing a fiver with a significant pin weight centered two feet behind the rear axle will likely affect an E450 much more than an F450.
โMar-19-2017 06:00 PM
โMar-19-2017 01:15 PM
Dayle1 wrote:As far as the Sidewinder goes, the pivot moves but the weight still sits on the hitch which is still over the rear axle. The weight doesn't move, just the pivot.
I agree 100percent, I have seen a number of rigs setup that way for transient workers like welders , etc. It would take a very heavy fiver to impact front axle weight on an F450. Also, the Reese Sidewinder moves the pivot point back 2 ft behind the truck axle and no owner has reported sway issues even on SRW trucks. You won't have a tailgate, but you can notch the back corners of the flat bed and you can minimize how far back the hitch needs to be for clearance.
โMar-19-2017 01:11 PM
โMar-19-2017 12:08 PM
โMar-19-2017 11:52 AM
DSteiner51 wrote:PNW_Steve wrote:
Hey Everyone,
I am considering moving my 5th wheel hitch to another truck. The challenge with this truck (E450) is that it has a 10' flatbed.
I cannot mount the hitch directly over the axle unless I cut almost 2' off of the bed. Not a good option.
The obvious alternative is to move the hitch back far enough that the trailer clears the back end of the bed. I know that this is NOT ideal but
I have little clue as to what the down side to this move other than reduced tow capacity. Given that I want to tow a 14k trailer with an E450 I am hopeful that the weight won't be an issue.
What other concerns should I have?
Thanks.
S.
Been there, done that... 11 ft flat bed, 30,000 lb trailer, no problem. Makes the front slightly lighter but nowhere near as much as a bumper pull. takes off the front axle approx what a Diesel engine puts on extra over the gas and adds it to the rear. Makes for a puller in soft soil or snow.
I have towed gooseneck/5th wheels with the hitches 9 inches forward to 2 foot behind the axle and heard all kinds of claims from experts who knew it all. Smile, shake your head and walk away. Trying to reason is a waste of time especially when on the clock and time is money.
โMar-19-2017 10:57 AM
โMar-19-2017 09:19 AM
โMar-19-2017 09:10 AM
โMar-19-2017 08:47 AM
PNW_Steve wrote:
Hey Everyone,
Thanks.
S.
โMar-19-2017 08:06 AM
