TPMS sensors
SDM
On the 507 TST system would you use the short sensors or the flow thru?
3 REPLIES 3
fj12ryder
I have the flow-through sensors and if any went bad I would replace them with the standard sensors. The flow-through allow such a small flow of air that it takes a substantial amount of time just to add 5 psi to a 16" trailer tire.
I find that I take the darned things off to add more than a pound or two as it just takes so long to work with the flow-through. Not worth the hassle IMO.
Just my opinion doncha know.
Howard and Peggy
"Don't Panic"
Ed9824v
I Removed the. Lock SYSTEM and now. No differant then valve stem cap
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
BB_TX
Flow thru are more convenient if you need to add or release any air.
I have the standard sensors and have felt no real need for the flow thru as my pressures pretty much remain constant thru the travel season. Adjust the pressure in the spring and I am good.
