Nov-28-2020 07:02 PM
Nov-30-2020 08:36 AM
rockwind1 wrote:time2roll wrote:rockwind1 wrote:Maybe I miss interpreted what this said.
i have forgotten to put it in the usual 65hp tow mode,,, i can't believe that would do it but something certainly did.
sorry, it was probably confusing the way i worded it.
well, on my hydra chip, which is the tune setup from powerhungry performance, which i can switch tunes while driving, i downloaded 4 tunes to choose from as i drive,
#1 daily driver 65hp fuel sipper
#2 towing 65 hp
#3 towing 80 hp
#4 40 hp daily driver
so when i tow i put it in #2
i don't have a factory tow button to press like some vehicles, which is what i thought you were referring to
but i had been driving around in #1 before i hooked up my trailer and drove off and i didn't put it in the towing mode, #2 that i have been using for years.
i am pretty sure ihave done this before, and vice versa, where i drive with out a trailer and leave it in the towing tune. what i have noticed when towing but not in the towing tune is that it shifts harder
Nov-29-2020 07:01 PM
Nov-29-2020 06:23 PM
theoldwizard1 wrote:
I worked in transmission engineering over 30 years ago. While 250F is pretty hot for non-synthetic oil, it is not "over the limit". IIRC, things got bad over 270F. The simple thing to do now is pull the dip stick. If the ATF is still bright cherry read and does not smell "burnt", ho harm !
If you are using synthetic or even blend you have a lot more room. I think all Motorcraft ATF is semi-synthetic now.
BTW, you did the right thing, backing off.
Nov-29-2020 06:19 PM
Nov-29-2020 05:46 PM
time2roll wrote:
If you were running Type F fluid I would be a bit more concerned. Stay in tow mode to keep the TC locked and just continue on as you have.
Nov-29-2020 05:42 PM
Nov-29-2020 05:15 PM
Nov-29-2020 04:48 PM
Nov-29-2020 04:16 PM
rockwind1 wrote:cummins2014 wrote:rockwind1 wrote:cummins2014 wrote:
Never saw those temperatures after installing the 6.0 tranny cooler on my 99 Superduty 7.3 towing a 38’ fifth wheel. That 4R100 transmission is certainly not one of fords better transmissions . Google the fluid change on that 4R100 its very easy , and save yourself some money , I did it a few times during the nearly 16 years I had it .
There is a great transmission builder in Arkansas that specializes in the 4R100 that will put your transmission problems to an end . Brian’s Truck Stop
yes i have heard of him,,, at the time i got the john woods,, supposedly john woods was the west coast expert and brian was the east coast expert,, sadlly i am on the west coast so arkansas is long drive. it soundslike you have done fluid change yourself? how do you get the fluid out of the converter and cooler? never mind, i will google it. thanks
Before I decided to trade in my 99 Superduty, I was going to go with the BTS , instead of the John Woods, from everything I read the BTS was the better tranny build. I actually talked to him about a shifting problem, that was intermittent , and he sent be a valve body, thinking that was my issue . Every rebuild he does he puts in a new valve body regardless, so the one he sent me was supposedly a used one ,but okay. All I paid was the shipping. Never got around to replacing it, seemed to start shifting okay, so I just let it go. As far as tuners again ,probably one of the better ones ,and the one I ran was the DP tuner. It had a tow tune ,as well as others, plus the stock tune as well . I also went with the AIS air intake ,4" exhaust turbo back. The truck ran very well, but short of changing turbos ,injectors etc ,it just didn't have the power in the mountains for a 38' fifth wheel that I would like.
As far as the fluid change ,yes just google it ,its easier then me having to explain it, but yes the old fluid gets pumped out of the converter, and as well as the cooler, its actually as said very easy.
I totally agree, even towing just a 33 foot toy hauler in the mountains is a struggle with my 2001, almost any grade above 5% and I’m in second gear going about 43 miles an hour, one time on a little Highway Inn between Benton California and mammoth, I couldn’t even do that, I was in first gear I barely made it over that little summit. Although I love my truck, I like how easy it is to work on, I like the fact that it doesn’t have all of the smog **** that every other truck has, and I like that I don’t have to put in that exhaust fluid
But I do get a little jealous of the newer trucks in the way they blow by me doing 85 mph up a grade pulling a 40 ft trailer
Nov-29-2020 03:42 PM
Nov-29-2020 03:38 PM
topjimmy wrote:
Don't have a Ford but I had a Bully dog tuner when I bought a used 2007 Duramax so I said great and tried it on tow mode on my maiden Voyage with my 5er I found out REAL QUICK going up my first stepper grade this thing SUCKS for towing my EGT's went too high and so did the tranny temps so I turned it back to Stock mode and all good again now I do not even use the tuner except for info Canned tuners suck IMO for towing
Nov-29-2020 03:30 PM
voodoo101 wrote:
I have a 2001 F-250 7.3 and I had to watch my tranny temps all of the time until I put the Ford V-10 tranny cooler on it. Now I never see 200 degrees. It is 40 percent bigger than the oem and comes standard with Ford tranny replacements. It should have been oem to start with since the 7.3 puts a bigger load on the tranny. Since it is an OEM for the V-10 it fits right on the bracket with no modifications.
Your Woods tranny may already have the larger cooler.
Good luck.
Nov-29-2020 03:29 PM
Lwiddis wrote:
“i have learned that this is the best way to get my tranny temp down) went about 50-55mph for maybe 15-20 minutes and got it back down to 145-150 degrees.”
Another reason to slow down.
Nov-29-2020 09:48 AM
