TST 507 Repeater Installation Location
Splashers3
For folks that have the TST 507 repeater:
I just received my TST507 repeater because I was losing sensor signals. You folks that are using the repeater, where did you place it? Is it better to have it closer to the sensors or closer to the display?
I was thinking of placing it in my 5ver's basement, but was concerned that it may not receive/send signals as well. Don't want to mount it outside the rig if I don't have to.
What have you guys done?
Thanks in advance,
Mike
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
17 REPLIES 17
Ed9824v
Mine is in the cabinet under fifth wheel and used the hot lead off compartment light fixture
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
evanrem
I mounted mine in the front pass though and connected it to the marker lights. The whole system works much better now.
BB_TX
I have a 12 volt plug under my truck back seat. So I mounted my repeater to my back window using a double sided adhesive strip. I spliced a small rotary switch in the positive wire so I can easily turn it off and on without having to raise the seat to plug/unplug it.
