Vanleigh dining area - One slide inoperable
tourusa
Hi all slide issue with lippert slide in the dining area,
Steps we have taken
1. All 4 slides go in no problem.
2. 3 slides go out no problem. 1 Except the dining area slide.
3. The voltage in the x2 batteries is 13.4 volts
4. We are connected to 50 amp camp site power
5. We are level ground
Iโ€™ve ordered a new switch for the slide panel, any thoughts
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
14 REPLIES 14
tourusa
Have a switch arriving today hope that all it is
F350 dually 2020
ITEM # BWRVK3305
Cptnvideo
Try swapping switches. If the problem follows the switch, then the switch is the problem.
Bill & Linda, 2019 Ram Laramie 3500 dually 4x4 diesel, Hensley BD5 hitch, 2022 Grand Design Solitude 378MBS, 1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LFP batteries for 1030 ah
tourusa
Thanks yes itโ€™s removing the patch from underneath any ideas where I can get replacement fabric
F350 dually 2020
ITEM # BWRVK3305
fj12ryder
I would imagine that the switch just reverses voltage, running the motor the opposite of when it comes in. So you could try reversing the switch wiring to see if that would make a difference, or check the motor where the wires connect and see if you have power on both wires when operating in and out. I agree that it's either the motor or the switch. Could be something as simple as a loose connection.
Howard and Peggy
"Don't Panic"
tourusa
I have a third party warranty may be time to try it out if the switch doesnโ€™t fix it
F350 dually 2020
ITEM # BWRVK3305
tourusa
Opposite side to the slide where I had to crank it out,
F350 dually 2020
ITEM # BWRVK3305
tourusa
F350 dually 2020
ITEM # BWRVK3305
tourusa
Have a switch coming and any ideas why the motor would work to get the slide in but not out
Iโ€™m guessing the previous owner had to replace at some point looking at the patch underneath? Is this where the motor would be
F350 dually 2020
ITEM # BWRVK3305
johntank
Seeing that you have electric motors for the slides I will say either you have bad switch or motor.
tourusa
F350 dually 2020
ITEM # BWRVK3305
tourusa
Iโ€™ve only found one resettable fuse
F350 dually 2020
ITEM # BWRVK3305
tourusa
No noise no pump comes in no problem doesnโ€™t go out
The other 3 slides no problem
F350 dually 2020
ITEM # BWRVK3305
tourusa
F350 dually 2020
ITEM # BWRVK3305
fj12ryder
Are these hydraulic slides, I'm assuming they are. Are they all operated from the same switch? How is the fluid level? Does the pump motor seem to strain when it tries to put out the last slide? Do the slides go out in the same order as they used to? Is the dining room slide smaller than the other slides, besides the bedroom? Any funny noises?
Howard and Peggy
"Don't Panic"
