Jul-05-2019 11:07 AM
Jul-13-2019 05:52 PM
Jul-13-2019 01:34 PM
Jul-08-2019 06:26 PM
bpounds wrote:philh wrote:
I'm wondering if we will ever use ours. If we do, may consider Grill Grates Link
Had to replace the grates on our park model BBQ, and LOVED IT. For the cheap onboard coleman grill, added the grates, and the thing actually works now!
Why would you put those in a propane oven? Aren't they just a BBQ grill gizmo, to prevent flare-up or make clean-up easier? I'm not seeing a point to using in an oven.
Jul-08-2019 03:55 PM
Jul-08-2019 03:15 PM
Jul-05-2019 06:22 PM
Big Katuna wrote:
Add a pizza stone or two.
Get an oven thermometer that hangs from a rack. SNIP
Jul-05-2019 04:54 PM
Jul-05-2019 04:18 PM
Jul-05-2019 04:15 PM
Jul-05-2019 03:51 PM
Jul-05-2019 02:16 PM
Jul-05-2019 02:08 PM
Jul-05-2019 01:15 PM
Chris Bryant wrote:
You can probably calibrate the thermostat- I don’t have anything on the furion, but most oven thermostats you can pull the knob off and there is an adjustable set screw in the center of the shaft- I turn it on, set to 300, let it stabilize temperature, see what the temp actually is, then I hold the set screw stationary and turn the shaft to approximately the correct position, then turn the temp up and see how close it is.
IMHO, this should be a warranty item, Furion might disagree.
ACZL wrote:
Have to use the baking stone that comes with it (or at least they did come with it). Think last time we used ours had to turn temp above what recipe called for to get/maintain temp. DW has used the convection nuke-o-matic a couple of times and things didn't turn out too bad. Only reason we have a gas oven is in the event power goes out.
FTG, I think there was a problem w/ the temp setting on the Furrion ovens (can't say for certain) and Lippert sent owners updates I think.
