1998 Safari Serengeti electric diagram or schematic
Pmahl
I am a new owner of a 1998 Safari Serengeti dp. I am having electric issues with my generator and am looking for any type of diagram or schematic to help trace back my problem. Any help is appreciated.
Peter
4 REPLIES 4
MrWizard
Moderator
Moderator
Probable cause is dirty or loose connection where the remote wiring plugs into the Onan,
Unplug connector, and spray it with contact cleaner,
Spray both sides the wiring harness plug, and the mating side on the onan
I can explain it to you.
1997 F53 Bounder 36s
Ivylog
Does it start from outside?
Upgraded with a 08 HR Navigator 45โ€™...
Pmahl
I should have included that info. It is an Onan 7500 diesel generator. There is nothing happening when using the toggle to start it from inside the coach.
MountainAir05
need a name on The generator and model # if you are talking about the aux gen for the RV. If for the engine the same info. What is it not doing.
Maybe here:
https://www.irv2.com/forums/f115/wiring-diagram-for-1998-safari-serengenti-289903.html
