2000 Monaco - Air pressure switch for co pilot floor slide
Marv_Hoag
I know there is a pressure switch located on the front firewall made by MAC that is supposed to be adjustable. The step flor slide needs to be slowed down have no idea how to make any adjustments to reduce the pressure. Any help greatly appreciated.
2000 Monaco Windsor 40
2009 Honda Fit Sport
2012 Chevrolet Equinox
2 REPLIES 2
dougrainer
If you look closely, it usually has the arrows showing which way to turn them. BUT, I have found that after years of use, the Valve is worn out and needs replaced, because you cannot adjust them. Doug
Ivylog
Most adjustable pressure regulators increase the pressure when you turn the adjusting screw CW and decrease when turned CCW. If you cannot find an adjustment I would decrease the air flow by clamping the supply line until the slide moves slower.
Upgraded with a 08 HR Navigator 45โ€™...
