2002 Windsport 35D needs a toad and I need help.....
disbound09
Good Day and advance thank yous for allowing me to join your club. I recently purchased my FIL 2002 Four Winds Windsport 35D its 37' He suffered a stroke that makes him unable to use it.
It has sat for 4 years in Michigan. It is winterized. I need to drive it to Dallas Texas around 1200 miles.
I decided to put new tires all around as they are the originals. He started it once a year and let it run for 30 minutes always starts right up.
I am looking for advice on a toad, I own a 2003 Trialblazer LT can it tow it without causing problems?
Also any advice for what I should prep or do before I take it on the road after such a long time sitting idle? Oil change and checking brakes are scheduled along with the new tires. Thanks!!
1 REPLY 1
Mandalay_Parr
I would call CoachNet and purchase roadside service. They will also cover your toad.
Consult the toads manual for towing requirements.
You will need a tow bar, lights and brake system for the toad.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
