2004 winnebago adventurer
murphy8
2004 winn adventurer
workhorse chassis 8.1 vortex
when under 30 degrees transmission wont shift starts out in 2nd gear i believe. if i drive a mile or 2 shut it off and restart it shifts fine. this always does it when cold,then i can drive all the way to florida with no problems. ive had rv for 8 years .but im leaving later this winter when its sub zero. im afraid it wont warm up enough.
any clues thankyou
8 REPLIES 8
allbrandauto
you can email me at allbrandauto@aol .com I can walk you through your problem
murphy8
Thanks that helps..
allbrandauto
2nd gear is a default mode you have a electrical problem maybe a shift soliniod maybe the trans. control module you need someone that has a scanner most automobile repair shops will have a scanner that has workhorse software
ArchHoagland
How long has it been doing this?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
K_Charles
What code did it set?
Lwiddis
After 21 years of service, seems time for pro to examine your transmission.
murphy8
i did still does it
midnightsadie
might change the tranny fliud.
