โMay-21-2021 06:47 PM
โMay-29-2021 08:31 PM
rjstractor wrote:And here we have first-hand experience being posted.ron.dittmer wrote:
I understood that a chassis with the motorhome prep package has a higher amperage alternator than a box truck chassis. This addresses most people's needs but Brian has some unique plans.
I imagine Ford's ambulance prep package (with twin alternators) would be ideal for his plans. Apparently the Ford parts guy he was working with was too lazy to determine what is needed from the ambulance prep package.
Brian, I wonder if a Helm shop manual for your chassis will identify what you need.
It's a misconception that the ambulance prep package has dual alternators. It does have dual batteries and a 240A alternator and dual alternators is still an option, but the rest of the package has little to do with the electrical system and more to do with the auxiliary HVAC systems, front axle rating and required heat shielding. All of the newer ambulances that I've work with have automatic high idle. Ours do not have dual alternators, since apparently the 240A alternator is sufficient, and we've never had an issue with not having enough alternator output. The prevelance of all LED lighting has helped immensely with this.
โMay-29-2021 07:10 PM
โMay-29-2021 10:46 AM
brianjw wrote:
Iโm going to run a 400 amp hour lithium battery setup. I want to be able to run the roof top AC off of the Victron inverter while driving (or just quickly recharge the batteries while driving). The plan is to run a 60 amp sterling B2B charger off of each alternator, for a combined 120 amps to the lithium battery bank. I donโt want to overwork/overheat a smaller single alternator asking too much from it, and this seems like the safest way to do it. A little overkill, sure. No, I donโt want to have to rely on the generator while Iโm driving. In fact if the solar and alternator perform well enough the generator will come out.
โMay-28-2021 04:56 PM
โMay-23-2021 12:03 AM
โMay-22-2021 08:36 PM
โMay-22-2021 05:48 PM
theoldwizard1 wrote:pnichols wrote:
Large and reliable alternators will probably become more important as lithium coach batteries become more common in motorhomes. Supposedly lithium battery banks charge fast - but only if one has a charging method that can deliver the high currents that the batteries will accept. For dry camping - especially when many hours of enough solar aren't available - a large capacity alternator driven by an idling chassis engine might be very useful.
First, I would not want to try a put more than 100A into ANY battery for more than a few seconds. Bad things can happen and at that rate they will happen fast !
Second, you really should have a multi-stage charger to do the job properly !
Third, no automotive alternator is going to put out more than 13V "are idle". Typically it takes 1500-2000 RPM to get 14V. Buy a DC-DC charger.I think that emergency service vehicles often have dual alternators.
And that is the only reason why someone would purchase a vehicle with 2 alternators !
โMay-22-2021 03:37 PM
โMay-22-2021 01:41 PM
Home Skillet wrote:
You can always contact these people and see if they are working on a version for the 7.3L
LINK
โMay-22-2021 12:31 PM
โMay-22-2021 11:00 AM
โMay-22-2021 10:31 AM
brianjw wrote:
It was the Ford dealer parts dept, theyโve historically been awful.
Iโm not concerned about warranty, the second alternator wouldnโt be integrated into factory electronics at all. Iโve modified everything Iโve ever owned.
โMay-22-2021 10:25 AM
pnichols wrote:
Let me chime in here with some thoughts:
1. Large and reliable alternators will probably become more important as lithium coach batteries become more common in motorhomes. Supposedly lithium battery banks charge fast - but only if one has a charging method that can deliver the high currents that the batteries will accept. For dry camping - especially when many hours of enough solar aren't available - a large capacity alternator driven by an idling chassis engine might be very useful.
2. Since any vehicle's alternator is very important, having two on board - when one or the other is getting used a lot for high current lithium coach battery charging year after year - to me would be a necessity for equipment backup purposes should one or the other fail when drycamping. Always have a Plan B for critical Plan A failures!
P.S. I think that emergency service vehicles often have dual alternators.
โMay-22-2021 10:21 AM
