6 volt vs 12 volt batteries
davekmyta
Am I able to replace my existing 2 12 volt batteries with 2 6 volt batteries and not loose any capacity - or would I have to go with 4 6 volt batteries?
5 REPLIES 5
Crazy_Ray
Dave do you know how to use the SEARCH MODE or GOOGLE?? You need to google 12volt side of life and read and learn. JMO
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
CA_Traveler
In most RVs 2x12V will be less than 200AH and 2xGCs about 230AH. So you could get more capacity and other benefits of true deep cycle batteries. Make sure they will fit including the additional height of GCs.
2014 Grand Cherokee Overland
Bob
time2roll
pianotuna
Nomad III
Nomad III
Hi,
If the new batteries weigh more than the old batteries you may have increased capacity.
If you plan on running a large inverter then four batteries may be a better way to go.
Will they be flooded batteries or AGM?
If they are AGM then I personally would favor 12 volt jars.
Regards, Don
2oldman
no. please answer so we know you're for real.
