'93 Monaco Dynasty blowing spin-on inline hyd filters
erikkiehle
Hi everyone, I'm looking for some help tracking down an issue with my 1993 Monaco Dynasty. It has a Cummins C8.3 with Allison 3060 transmission.
I've having a "new" problem over the past year where on longer road trips I'm having my spin-on (like an oil filter but bigger) hydraulic filters rupture and spray hydraulic fluid all over my engine compartment. The first time I figured it was just a bad filter and it didn't recur for about 1000 miles. Since then it's been blowing out filters at an increasing rate. It doesn't seem to happen in-town or in traffic where my vehicle speed varies and has a chance to reset or return to idle.
When I'm on the highway for min 2.5 hours or longer cruising at 70 with engine RPMs around 2200 I think it seems pressure builds over time until the filter fails. Then I have to pull over and replace the filter and replenish fluid in the reservoir.
My regular mechanic doesn't troubleshoot hydraulics enough to want to tackle it. He suggested removing the belt-driven hydraulic pump and taking it to a hydraulic specialist shop here in Abilene, TX and have them test it.
My questions are:
1) Whether there's any other ideas as to cause of failure?
2) Are there any pressure bypass points elsewhere outside of the pump itself that could be failing?
3)Is there any better way to troubleshoot this? Is there anywhere in the system Monaco might have installed a pressure port or open connection I could put a pressure gauge on to monitor hydraulic pressure and any changes.
4) Now that hydraulic fluid has been sprayed all over my engine and exposed electronics repeatedly everything is still "wet" even months since my last episode. I had hoped the fluid would evaporate or dry up over time but it's soaked through and destroyed the heat barrier on the lid/bed bottom board. How best to clean the electronics and wiring in the engine area and should I replace the heat shield and if so what should I use?
Lastly, my wife now refuses to take trips in the motor home after many long-term issues. For years we had repeated alternator failures until I myself identified and replaced the voltage sense wire. The original wire must have a weak spot which would cause (at random rare times and intervals) for the alternator to either spike to 16+ voltage output or turn itself off entirely. No shop could ever offer a solution beyond replacing alternators and ruined batteries.
So I'm asking here about this hydraulic problem and once fixed this 1993 34' Dynasty will be up for sale. Best offer gets it or it'll go to auction in springtime.
Thanks!
Erik (near Abilene, TX)
14 REPLIES 14
calvin5445
I have sepnt many years selling and repairing hydraulics. The filters should be on the return line. They make High pressure and low pressure filters. If it is on the pressure side, maybe someone put a low pressure filter on. Could be the relief valve on the pump or valve.
Calvin 89 Monaco
rgatijnet1
I don't know of any hydraulic system that does not have a high pressure bypass. Some bypasses are even in the filter itself to bypass the fluid if pressure builds up due to the filter becoming clogged.
Are you 100% positive that you are using the correct filter for this application? Many filters look alike and would fit in the same location but internally they are different.
erikkiehle
Nope, never got it figured out. Sold the coach this winter to someone with full disclosure and buyer had a background in commercial trucking.
Next step if I had kept the coach would have been to have the pump bench tested at load for 6 hours to see if an internal pressure regulator was the problem.
Jskadb
Erik
Did you ever find out what was causing your filters to blow? I have a Monaco 93 Crown Royal and have the same problem, except mine blows the shaft seal out on one of the hydraulic motors sometimes.
Thanks
Joe
randallb
E,
The return restrictor is simply a pea placed in the return line near the reservoir. You can usually see a slight bulge in the return hose.
Randy
MrWizard
Moderator
Moderator
As tech who spent years working on CNC, industrial machines and robotics, with high pressure hydraulic systems
You have a restriction problem somewhere in the system
Or the hydraulic pressure regulator ( if one exists in your system ) is malfunctioning
When pumps fail they loose pressure, unless there is an internal regulator that is failing
Machine systems all had external regulators attached to the output of the pump, which then feed the manifolds containing the valves
So those are the two choices, restriction
Or
Failing regulator ... internal or external
I can explain it to you.
1997 F53 Bounder 36s
erikkiehle
wolfe10 wrote:
Not sure I understand why you would have two different filters on a hydraulic system. This is particularly true if you have the large canister with a stack of 2-3 filters. That is a LOT of filter media with very little restriction due to surface area.
Out of curiosity, check the micron rating on the large canister, stacked filters vs the spin on unit.
Now, if you actually have two separate system, one for PS and one for the fans, the two filters make perfect sense.
Yes, my coach has the stack of filters in the canister reservoir. Will check micron ratings and call Monaco Tech Support to see if they can confirm I'm using the right filters.
randallb wrote:
Only one thing blows up filters and that is excessive pressure. Not having enough information to find the schematic for your system you will either have an inline pressure bypass valve or an internal bypass in the pump. One or the other is allowing the pressure to grow until the filter blows. It could be that someone has mickey moused the system to increase pressures because of a faulty fan drive or other issue with this portion of the cooling system. The stacked filters in the reservoir may be partially clogged restricting the intake to the pump and this was "corrected" by playing with the bypass, if it is external. Pull the pump, have it checked but be sure to tell them it occurs after an extended run. Otherwise they will run it for a few minutes and possibly pronounce it good to go. If it checks out ok start looking for wires disconnected, spliced together or other obvious signs that someone did not want to spend the money to fix a previous issue in a proper manner because of cost. This could easily be something as simple as a return line restrictor, normally installed near the reservoir for noise reduction or splash control, that has become partially blocked with age. Good luck with the repair. I hope you can do this yourself because it will get very expensive to have someone else do it.
Randy
So I know the spin-on filter is new as I've replaced it 5 times in the past year or so. I'll pull and change the filters in the canister too. Here's hoping it's that simple and cheap. ๐Ÿ™‚
My regular mechanic also suggested pulling and bench testing the pump but I will definitely let the shop know the pressure builds over 4 hours not 4 minutes! Good suggestion!
If I can get under and trace the hose route what would I look for in terms of an external bypass as opposed to a bypass built into the pump itself. Would it look like an inline check valve or would it be more of a T where it would divert extra pressurized fluid back to the reservoir?
Also, what might a "return line restrictor" look like? Would it be right at (or in?) the canister filter?
Thanks!
randallb
Randy
wolfe10
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
erikkiehle
dangerbird wrote:
I would agree with wolfe10. In many years of working on heavy equipment, I don't recall a filter in the pressurized side of the pump. Usually it's in the return line to the tank.
Carl
I'll have to trace the lines a bit. I had thought the pump's pressurized output went forward to the steering and the lines on the way back went through this filter before the hydraulic fans.
There is a set of filters stacked within the main reservoir at the engine door next to the roof ladder. Maybe this spin-on filter is just an extra filter for protection of the sensitive and expensive hydraulic fan motors. I could see enough to see that after the spin on filter the fluid ran to the fans and fan controllers.
I posted in the hope someone had experienced this before and hopefully could point me straight at the likely fix. As with so many things I'll keep poking but I do appreciate any and all suggestions of things to look for and try!
dangerbird
Carl
wolfe10
Verify the filter is on the return line/low pressure side of the hydraulic system.
On that age coach, someone may have replaced hoses and mis-plumbed it.
Brett Wolfe
Ex: 1997 Safari 35'
erikkiehle
DSDP Don wrote:
Hopefully a hydraulic engineer with some knowledge of RV hydraulics will post and can describe if there is some type of pressure regulator that can be adjusted or replaced.
Fingers crossed. ๐Ÿ™‚
DSDP Don wrote:
Out of curiosity, what brand of filter are you using. Is there an OEM filter available and have you tried one. The reason I ask is that some spin on filters have a built in bypass.
I've gone through a few filters. The original one was probably (frighteningly) the original. It was a Fairey Arlon FA35-25. Those aren't widely available if at all and there was no date written on it. I have started writing install date and mileage on all replaceable filters whenever I can, but I have no idea how long this filter had been in place. I've been using different cross-reference filters from the FA35-25, and currently have a WIX in place because I was able to grab 3 of them at an auto-parts store to have spares on the road.
DSDP Don wrote:
What is that pump supplying, power steering, side radiator fan??? Do you have any issues with those?
The hydraulic pump is driven off the engine with a dedicated belt. It powers steering and 2 hydraulic fans on the side radiator. No apparent problem with those though sometimes I'll hear a little whine from the steering during turning. I replaced one hydraulic fan a couple years ago and maybe (or not) the hydraulic filter was replaced by the shop at that time. I haven't looked at that expensive receipt. I may have burned the receipt in a fit of spite over the total bill. Not sure why hydraulic fans were used instead of commonly available automotive electric radiator fans. The hydraulic motors are crazy expensive, not widely available so parts have to be ordered, and require people trained or competent in hydraulics to replace. If I were going to keep this coach I'd probably replace the fans with electric motors just for reliability.
DSDP Don wrote:
Lastly, if there are no solutions, I would replace the hydraulic pump with a new or rebuilt model.
Yea, that's on my list of options. Being nearby oil fields the hydraulic shop in town does a lot of rebuilds or may have an alternate. My mechanic said he could just plumb around the filter and effectively remove it from the system but then if an overpressure situation occurs I wouldn't want to burst a line. A spin-on filter I can carry a spare (or 3-4) and replace on the side of the road. A burst hydraulic hose isn't within my capability or desire to mess with. So I'm most interested in learning how our hydraulic system are plumbed and how they regulate pressure.
DSDP Don wrote:
Hopefully you're not giving up on RVing and will buy another, maybe newer.
Well we're still youngsters (39 and 42). We bought the coach in '09 after a job loss when we knew we were moving but didn't know where. We spent the summer full-timing with our kids and driving all over California, and Texas visiting friends and family and going on job interviews. We settled in Texas and kept the motor home for long distance road trips to visit my in-laws in Mississippi every holiday and during the summer. It's a great road trip vehicle with room for the kids to not be kicking each other, toilet immediately available and even once heated up a can of soup while stopped for a 1/2 hour because the highway was blocked by an accident.
Around town we were fine with our sedans but for road trips taking the dogs and luggage and stuff we used the motor home. We had a new baby this summer and finally needed a minivan for even in-town use. With a minivan option for road trips it just doesn't make sense to keep our coach. When we reach retirement age I definitely will consider another one, but for now it'd be better used by someone else.
DSDP_Don
Hopefully a hydraulic engineer with some knowledge of RV hydraulics will post and can describe if there is some type of pressure regulator that can be adjusted or replaced. I'll just throw out some things in the meantime.
Out of curiosity, what brand of filter are you using. Is there an OEM filter available and have you tried one. The reason I ask is that some spin on filters have a built in bypass. Possibly, a cheaper quality filter may not.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
