A few questions?
udidwht
Picking up my 1994 Southwind Storm 28ft I purchased today and was wondering...Was planning on doing oil, trans fluid, diff. oil and radiator/T-stat. Kinda wanted an idea of what I'm going to need in terms of fluids and amounts.
1. What is the coolant system capacity? Total
2. What is the fluid capacity of the transmission?
3. What type fluid is used in the trans?
4. Differential fluid...How much?
5. Generator oil type and how often to service? Items such as air & oil filter can be purchased where?
6. Suggestions on oil grade/viscosity used? (Chevy 454)
A bit about the RV...It's in very good shape and has been barned when not in use. Roof has been re-coated & resealed, new tires (Michelin), New brakes, rotors and calipers, tuned-up recently, New gaskets and headers, all interior electrical items work great, all ext. items function great, 45,XXX miles, 2 owner RV. Asking $10,000 but I offered and purchased it for $8500.
Much appreciated,
Jim
1994 Fleetwood Southwind Storm
P-30 chassis 7.4L 454 TBI 58,301 miles and counting....(as of 06/08/19)
VIN# 1GBJP37N4R3314754
Flight System Generator man 360 (PM me)
3 REPLIES 3
udidwht
Thanks, I was going to use Valvoline 10w-30 VR-1 in the engine.
Anyone know if the trans service requires anymore beyond a simple drain and changing of filter? Does it require torque converter draining or band adjustments?
Sully2
It should have an owners manual that contains every bit of the info you asked about
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
Trackrig
I'll let you decide which oil, but I'd use the same oil in both the generator and the main engine. It prevents mistakes and one less bottle to carry. Assuming you have levelers, I'd change the oil in them also. People seem to dump all sorts of things in the levelers if they get low.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
