Jul-06-2018 07:13 PM
Jul-07-2018 06:25 AM
Jul-07-2018 03:49 AM
Jul-06-2018 09:15 PM
MrWizard wrote:
want to know what volatge the A/C unit is seeing
remove the covers from the circuit breaker panel
use a multimeter set on AC volts 200vac or higher (usually something like 600vac on the meter )
read from the neutral bar (the white wires buss) to the A/C breaker
probably safer if you get somebody else to do it
Jul-06-2018 09:13 PM
pianotuna wrote:
A 30 amp service should only be used at 24 continuous.
If the autoformer is raising the voltage 10%, then on the input side of the autoformer the current would be much higher than 29 amps.
Anything above 107 volts is safe for the air conditioners. How are you checking the voltage inside the RV?
Jul-06-2018 09:10 PM
Jul-06-2018 08:48 PM
Jul-06-2018 08:00 PM
Jul-06-2018 07:54 PM
Jul-06-2018 07:38 PM
