Access to kitchen sink leak
IamSiler
When kitchen faucet is on, water leaks from under the “floor” of the cabinet onto the coach floor. Can see no leaks from pipes when looking under the sink but cannot find access to area below cabinet floor. Don’t see any access underneath the coach either.
4 REPLIES 4
IamSiler
Thank you!!
johnsonbert
Many of those cupboards have a false floor in them. It will require removing everything from the cupboard and checking for screws or fasteners that hold the floor in place. Most of ours are held in place by a couple of screws and then the weight of the contents does the rest. Most are two piece to make them easier to remove and replace. Hope this may help. Happy Trails Bert
2006 Monaco Dynasty Diamond IV 42' Tag, ISL 400,(new to us), Residential Refrig, 10KW Onan, Bosch Washer/220V Dryer (previously 2003 American Tradition 40W) 2010 Chev Malibu LT
IamSiler
Thank you for the response!!
We do have a false floor. How do we access between it?
midnightsadie
welcome to rv repairs ,wipe your hand around the drain pipe as it goes to the floor ,use a tissue it,ll find leaks if its thru the floor just gotta hunt you might have a false floor that the pipes run in. some times these leaks can cause real bad headaches.
