โJun-17-2017 10:30 AM
โNov-17-2021 07:19 PM
โNov-15-2021 06:27 PM
โNov-15-2021 06:25 PM
โNov-15-2021 06:23 PM
โNov-15-2021 06:19 PM
โNov-15-2021 06:16 PM
โNov-15-2021 06:15 PM
PastorCharlie wrote:
HERE ARE SOME GOOD INSTALL GUIDES
I do not cut corners when installing the FRP. I use a good coverage of adhesive and press it on firmly and use plywood pads with bracing to hold the FRP to wall until dry. I like a solid feel when pressing the FRP wall and not puffy voids.
I have had good success with mine. I used a plywood backing. What you have on your walls will work fine.
I have had good success with my installs. I use A/C plywood backing. What you have on your walls will work fine. I use a very small bead of clear tub chalking in the corner channels of the trim pieces before slipping them over the edges of the FRP. Makes for a perfect corner seal. I use painter's tape along both sides of all seams when calking wall to tub basin, etc. Remove tape carefully before chalk dries and smooth chalk with wet finger. I dislike a messy chalking job.
I have done jobs where I ran the FRP horizonal on the bottom half of wall and finish the top half with another material to compliment it. Different strokes for different folks.
โNov-15-2021 06:01 PM
โNov-15-2021 11:15 AM
โNov-15-2021 03:05 AM
FRP makes a good wall covering if properly installed.
โNov-14-2021 01:10 PM
โNov-14-2021 08:27 AM
โNov-14-2021 08:24 AM
โNov-11-2021 07:09 PM
โNov-09-2021 06:46 PM
When I build tanks I use 3" wide fiberglass rolls and do all the corners' walls and bottom. I run 1 1/2" up one side and 1 1/2" up the other side giving a good seal. The cloth can be cut and lay flat on the bottom and the sides over laying the 1 1/2 " of the 3" cloth and no need to work the large sheet around corners and joints.
